akkadhim1
Zynq Frequency scaling
I'm trying to scale the CPU frequency to the lowest frequency 333333 kHz but I got the below error
cpu cpu0: failed to set clock rate: -16
My devicetree pcw.dtsi file has the following settings:
cpus {
		cpu@0 {
			operating-points = <666666 1000000 333333 1000000>;
and zynq-7000.dtsi file has the following:
cpus {
		#address-cells = <1>;
		#size-cells = <0>;
		cpu@0 {
			compatible = "arm,cortex-a9";
			device_type = "cpu";
			reg = <0>;
			clocks = <&clkc 3>;
			clock-latency = <1000>;
			cpu0-supply = <&regulator_vccpint>;
				/* kHz    uV */
				666667  1000000
				333334  1000000
		cpu@1 {
			reg = <1>;
			clocks = <&clkc 3>;
is this the reason behind that error  (different frequencies) or there is another issue?
I configured the kernel and the governor is the userspace as below:
# cat scaling_governor
userspace
also can I add another operating frequency like 222222 KHz? and do I need to change just the devicetree file?
My current available frequencies:
# cat scaling_available_frequencies
333333 666666
Regards.
austin
ds187,
Table 21: PS PLL Switching Characteristics,
FPSPLL_MIN PLL minimum output frequency 780 MHz.
There is hardware to consider.  Not every number is allowed.  Read the data sheet.
Austin Lesea
Principal Engineer
Xilinx San Jose
austin
ds187,
Austin Lesea
Principal Engineer
Xilinx San Jose
akkadhim1
Thank you @austin
I got the idea, I have to activate the PLL bypass to select the 333333 frequency, as explained in the below link.
http://www.wiki.xilinx.com/Zynq-7000+AP+SoC+Low+Power+Techniques+part+5+-+Linux+Application+Control+of+Processing+System+-+Frequency+Scaling+%26+More+Tech+Tip
About the operating frequencies, I checked the document you mentioned and in table 17, it is possible to select the frequency 222 MHz, so how can I include this frequency? just add it in the devicetree?
Regards.
vibishna
I hope setting the cpu governor to userspace helped to avoid the "cpu0: failed to set clock rate: -16" error
You can definitely add the additional frequency in your clock tree:
cpus {
         cpu@0 {
                         operating-points = <0xa2c2b 0xf4240 0x51616 0xf4240 0x3640f 0xf4240>; // 666667 1000000  333334 1000000 222223 1000000
It will be listed in the "cat scaling_available_frequencies"
But for some reason it is given in one of the Xilinx forum that the lowest frequency of 222Mhz is not reachable in default configuration.
I am trying to figure out why is the lowest frequency not reachable!
akkadhim1
Hi @vibshna
Thank you for your response.
Yes I read that also, but I think if you followed the method in this application you can do that:
Regards.
vibishna
Hi @akkadhim1
Can you tell me if you were able to fix the problem of  setting to 222Mhz? If yes, please tell me exactly which step solved the problem!
akkadhim1
hi @vibishna
unfortunately, I haven't solved the problem, and because my project deadline was due,  I simply stopped working on it. I'll let you know if I get around the project again.
