Zynq - MMU Setting for PL Memory Region
Hi all,
I'm working on zc702 compatible development board for my project.
For my board, a 1GB DDR Memory is mapped to 0x0000_0000 ~ 0x3fff_ffff as a default
and I have added 512 MB DDR Memory with the address range : 0x6000_0000 ~ 0x7fff_ffff.
(I used GP0 AXI port)
Since my goal is to inspect AXI-based memory transactions in PL area,
I ported xilinx-zynq-linux to my board with (UIMAGE_LOADADDR = 0x60008000) setting.
(And I modified dts for memory mapping)
With DS-5 debugging supprot, I found that my system failed to enable MMU.
In a linux kernel startup function __setup_mmu, kernel initialize page section entries with appropriate attributes.
Because my linux kernel is running on 0x60000000 ~ 0x70000000,
the page entries for the region has Cacheable(C) and Bufferable(B) attributes.
When I ported the linux at 0x20000000 ~ 0x30000000, these attributes did not make any problem.
But, for newly added memory region, Cortex-A9 could not enable MMU.
It makes error continuously with the instructions below.
mcr p15, 0, r0, c7, c5, 4 @ ISB
mcr p15, 0, r0, c1, c0, 0 @ load control register
(pending here)
mrc p15, 0, r0, c1, c0, 0 @ and read it back
I don't know what I shoud do for solving this problem.
Address mapping for PL cannot be used as instruction memory?
Or, can I make it possible with some settings in PS?
Hi hig1012,
Did you ever figure out this problem? I'm running into similar issues and am curious how you solved the problem.
Chandan
