imgignacio
Zynq MP Ethernet SGMII GT Transceivers
Dear Forum,
is there any example of device tree for the Ethernet Phy when the GT transceivers are being used as phy (SGMII)?
I mean this configuration:
Unfortunately I cannot find any information about what the driver expects and I need to create a valid device tree with this configuration for ethernet on my board to work.
According to this AR, it should look like this:
https://www.xilinx.com/support/answers/66592.html
&gem2 {
        phy-handle = <&phy0>;
        phy-mode = "sgmii";
        phy0: phy@0{ <- is this always 0?
                reg = <0>; <- is this always 0?
                ti,rx-internal-delay = <0x8>;
                ti,tx-internal-delay = <0xa>;
                ti,fifo-depth = <0x1>;
Also, what about the serdes? Must a line be added, like with USB3 or PCIe? Like this:
<&lane3 PHY_TYPE_SGMII 3 3 125000000>;
Thanks in advance!
Have a nice weekend!
Ignacio
pillinj1
I had that same question as you for a long time. I did finally get it to work with the near exact device tree you had
&gem0 {
    status = "okay";
    phy-mode = "sgmii";
    phy0: phy@0{
        reg = <0>;
        ti,rxctrl-strap-worka;
As you can see, there's no SERDES config line (in my case it would have been "phys = <&lane0 PHY_TYPE_SGMII 0 2 125000000>;")
pillinj1
&gem0 {
    status = "okay";
    phy-mode = "sgmii";
    phy0: phy@0{
        reg = <0>;
imgignacio
Hi @pillinj1,
thanks a lot for your answer!
Ignacio
imgignacio
Hi @pillinj1,
may I ask you which PHY you were using? Did you have to do any modification on the FSBL for the GT transceivers to work?
I am triying this connecting to a switch with a SGMII integrated PHY. Linux says there's link and the TX packet counter shows a number with no errors. Nevertheless, the RX packet counter is always 0 and there's no way to send/receive any kind of packet.
Thanks in advance!
Ignacio
pillinj1
I'm using GEM0 (so GTR0) and am bringing in the reference clock on GT Ref Clk 2. I did not have to make any manual modifications to the FSBL. I had it working with 2017.3 and 2017.4 FSBLs.
Edit: the phy was the same as the ZCU102 (TI DP83867) but wired for SGMII.
baruchlerer
Hi I have the exact same issue, did you finally solved it, if so can you share how?
I'm using petalinux 2018.1
Many Thanks
Baruch
stw-prepelica
Hi!
have you solved it? I know, it's been a long time since your reply on this topic but maybe you could give me a hint?
