ajeetsm_
Zynq PS PL Interface
I made basic calculator in PS(Processing System) of Zynq 7000 SoC in XCZ7020 Zedboard using SDK.
Now I want to select operators using switches avaialable on the zedboard. How to do that?
reshmaakhil
hi @ajeetsm_ .
if you need just two push buttons, its available in PS of zedboard.
if you want to use DIP switches please refer to Adam Taylor's MicroZed Chronicles.
http://zedboard.org/content/microzed-chronicles
There is a section, starting with issue 21, that details about creating a PL based peripheral.
https://forums.xilinx.com/t5/Xcell-Daily-Blog-Archived/The-Zynq-PS-PL-Part-One-Adam-Taylor-s-MicroZed-Chronicles-Part/ba-p/418935
regards,
Reshma
reshmaakhil
hi @ajeetsm_ .
regards,
Reshma
ajeetsm_
Thanks @reshmaakhil. Let me try to implement the solution.
