Zynq Quad-SPI boot question
Good morning.
Ask for good feedback.
I am using vivado 2017.4.
And I am using the XC7Z010CLG225-2.
Quad SPI Single using S25FL256SDPBHICI0 product.
In the ZYNQ7 Processing System (5.5), I set the Quad SPI Single and the DDR PLL to 66MHz.
After creating bit file, I try to execute FSBL file and BIN file in program flash with SDK.
However, a 'FLASH OPERATION Failed' error occurs.
128M is possible with the same procedure.
Is there any other setting method when using 256M?
Thank you.
You can click on the check box in the Program Flash wizard to check whether the erase operation is successful.
Try on SDK 2017.2 , and if nothing works, there is an alternative way to boot board through JTAG mode and write directly to QSPI.
mrm
