Voyager
Voyager
Zynq S_AXI_HP0 - unresponsive to JTAG-AXI write transactions
Inside block design I have a JTAG-AXI master connected to the "S_AXI_HP0" port of a Zynq 7000 PS with an AXI-SmartConnect to translate beween the JTAG-AXI's AXI4 and Zynq's AXI3.
I also connected an ILA on the AXI3 interface between the SmartConnect and the Zynq's S_AXI_HP0.
When I force an ILA trigger I see:
1. The AWREADY line is a constant '0'.
2. The ARREADY line is a constant '1'.
The JTAG-AXI responds well to the read commands with correct data retrived.
However, it doesn't respond to write commands:
BVALID isn't returned, data isn't written and the following message is shown on the console a few moments after issues the command:
ERROR: [Xicom 50-38] xicom: AXI TRANSACTION FAILED
What can be the cause ?
Re: Zynq S_AXI_HP0 - unresponsive to JTAG-AXI write transactions
HI @shaikon
Did you initilalize the Processor? You might want to run an application to initialize it, then without powering off the board, just try the JTAG to AXI again
Florent
Voyager
Voyager
Yes I did.
As I said - I'm able to read but not write.
HI @shaikon
What address are you trying to access?
Florent
