01-21-2021 12:51 AM
Hello, I am working in Zynq SPI Slave interrupt mode, the exchange is going on, but the interrupt processing is not happening, what am I doing wrong, can someone have an example?
My code:
/***************************** Include Files **********************************/
#include <stdio.h>
#include <stdlib.h>
#include "xil_printf.h"
#include "xparameters.h" /* SDK generated parameters */
#include "xspips.h" /* SPI device driver */
#include "xbram.h" /* BRAM device driver */
#include "xscugic.h" /* Interrupt controller device driver */
#include "xil_io.h" /* I/O driver */
#include "Xil_exception.h"
#include "xil_cache.h"
#include "xil_types.h"
#include "sleep.h"
/************************** Constant Definitions *****************************/
#define SPI_DEVICE_ID XPAR_XSPIPS_0_DEVICE_ID
#define INTC_DEVICE_ID XPAR_SCUGIC_0_DEVICE_ID
#define SPI_INTR_ID XPAR_XSPIPS_0_INTR // XPAR_XSPIPS_0_INTR or XPS_SPI0_INT_ID ?
#define SGI0_INTR_PRI (0x78) // Highest Priority
#define SGI0_INTR_TRIG (0x03) // Rising-edge Sensitive
/**************************** Type Definitions *******************************/
/***************** Macros (Inline Functions) Definitions *********************/
#define SpiPs_RecvByte(BaseAddress) \
(u8)XSpiPs_In32((BaseAddress) + XSPIPS_RXD_OFFSET)
#define SpiPs_SendByte(BaseAddress, Data) \
XSpiPs_Out32((BaseAddress) + XSPIPS_TXD_OFFSET, (Data))
#define MAX_DATA 100
/************************** Function Prototypes ******************************/
int SpiSlaveInit(u16 DeviceId);
static int SpiSetupIntrSystem(XScuGic *IntcInstancePtr, XSpiPs *SpiInstancePtr, u16 SpiIntrId);
void SpiHandler(void *CallBackRef, u32 StatusEvent, unsigned int ByteCount);
void SpiSlaveRead(int ByteCount);
/************************** Variable Definitions *****************************/
static XSpiPs Spi; /* SPI Driver */
static XScuGic IntcInstance; /* GIC Driver */
u8 ReadBuffer[MAX_DATA];
int main(void)
int Status;
xil_printf("START \r\n");
Status = SpiSlaveInit(SPI_DEVICE_ID);
Status = SpiSetupIntrSystem(&IntcInstance, &Spi, SPI_INTR_ID); // начальная инициализация GIC и тестирование
while(1)
SpiSlaveRead(1);
xil_printf("ReadBuffer[0] = %08x \n\r ", ReadBuffer[0]);
xil_printf("STOP \r\n");
return XST_SUCCESS;
int SpiSlaveInit(u16 DeviceId) // SPI slave
int Status;
XSpiPs_Config *SpiConfig;
* Initialize the SPI device.
SpiConfig = XSpiPs_LookupConfig(DeviceId);
Status = XSpiPs_CfgInitialize(&Spi, SpiConfig, SpiConfig->BaseAddress);
Status = XSpiPs_SelfTest(&Spi);
Status = XSpiPs_SetOptions((&Spi), (XSPIPS_CR_CPHA_MASK) | \
(XSPIPS_CR_CPOL_MASK));
XSpiPs_SetRXWatermark((&Spi),1);
XSpiPs_Enable(&Spi); // включение
xil_printf("SPI config finish\r\n");
return XST_SUCCESS;
int Status;
XScuGic_Config *IntcConfig; /* Instance of the interrupt controller*/
Xil_ExceptionInit();
* Initialize the interrupt controller driver so that it is ready to
* use.
IntcConfig = XScuGic_LookupConfig(INTC_DEVICE_ID);
Status = XScuGic_CfgInitialize(IntcInstancePtr, IntcConfig,
IntcConfig->CpuBaseAddress);
Status = XScuGic_SelfTest(IntcInstancePtr);
* Connect the interrupt controller interrupt handler to the hardware
* interrupt handling logic in the processor.
Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_INT,
(Xil_ExceptionHandler)XScuGic_InterruptHandler,
IntcInstancePtr);
// Xil_ExceptionEnable();
* Connect the device driver handler that will be called when an
* interrupt for the device occurs, the handler defined above performs
* the specific interrupt processing for the device.
Status = XScuGic_Connect(IntcInstancePtr, SpiIntrId,
(Xil_ExceptionHandler)XSpiPs_InterruptHandler,
(void *)SpiInstancePtr);
* Enable the interrupt for the Spi device.
XScuGic_Enable(IntcInstancePtr, SpiIntrId);
XSpiPs_SetStatusHandler(SpiInstancePtr, SpiInstancePtr,
(XSpiPs_StatusHandler) SpiHandler);
* Enable interrupts in the Processor.
/* Set priority and trigger type */
XScuGic_SetPriorityTriggerType(IntcInstancePtr, SPI_INTR_ID, SGI0_INTR_PRI, SGI0_INTR_TRIG); // ?
xil_printf("GIC config finish\r\n");
return XST_SUCCESS;
xil_printf("interrupt \r\n");
if (StatusEvent != XST_SPI_SLAVE_MODE) {
xil_printf("XST_SPI_SLAVE_MODE \r\n");
if (StatusEvent != XST_SPI_RECEIVE_NOT_EMPTY) {
xil_printf("XST_SPI_RECEIVE_NOT_EMPTY \r\n");
if (StatusEvent != XST_SPI_TRANSFER_DONE) {
xil_printf("XST_SPI_TRANSFER_DONE \r\n");
int Count;
u32 StatusReg;
XSpiPs_SetRXWatermark((&Spi), ByteCount);
StatusReg = XSpiPs_ReadReg(Spi.Config.BaseAddress,
XSPIPS_SR_OFFSET);
* Polling the Rx Buffer for Data
do{
XSPIPS_SR_OFFSET);
}while(!(StatusReg & XSPIPS_IXR_RXNEMPTY_MASK));
* Reading the Rx Buffer
for(Count = 0; Count < ByteCount; Count++){
ReadBuffer[Count] = SpiPs_RecvByte(
Spi.Config.BaseAddress);
01-21-2021 03:26 AM
Can you please point me where are you monitoring and reporting as interrupt is not processing.
Venu
01-21-2021 04:45 AM
I want to just run the callback function(interrupt handler), when receiving the first byte in the FIFO, how do I do this?
callback function:
01-21-2021 11:21 PM
added a line
Xil_Out32((XPAR_XSPIPS_0_BASEADDR + XSPIPS_IER_OFFSET), 0x10); //irq enable
rigidly enable interrupts during initialization, the interrupt worked once, after that, in the callback procedure, it cut off the controller, also had to turn on the controller hard
Xil_Out32((XPAR_XSPIPS_0_BASEADDR + XSPIPS_ER_OFFSET), 0x01);//spi enable
it works, but this is not the way of the samurai, everything should work at the API level of functions
01-26-2021 04:05 AM - edited 01-26-2021 04:06 AM
XScuGic_Connect(IntcInstancePtr, SpiIntrId, (Xil_ExceptionHandler)SpiHandler, (void *)SpiInstancePtr);
to
not use
