devik
Zynq Spread Spectrum Clocking
I can't find any info whether we can use SS modulated clock as PS_CLK input.
Anyone know whether PS PLLs can track SS and what their bandwidth is ?
thanks, Martin
smarell
Community Manager
Community Manager
I haven't see any mention of this anywhere. For me it looks like it is not recommended as it is not documented anywhere.
movax
Found this on a Google search -- bumping to see if anyone looking here has used say a +/- 1.00% spread-spectrum 33.333MHz oscillator to drive PS_CLK.
The parts I'm looking at have shared footprints for SSC vs. non-SSC, but looking to save myself a little validation time / BOM swapping if possible...
devik
It is some time from my first post. I did some tests in meanwhile and can
say that Zynq with LPDDR2 @ 400MHz, PSCLK from CDCE913 at 33MHz
works even with maximum spreading supported by CDCE.
I measured DDR clock with spectrum analyser and it was spreaded
correctly.
Martin
movax
Thanks for the datapoint -- I think I'll start with a basic -1.00% or -0.50% SSC option, as not to push the frequency out-of-spec when multiplied up in a PLL. I have seen Ethernet and PCIe devices use SSC easily in the past, and the USB clock isn't sourced from the Zynq, so will see what ends up happening.
devik
WRT Ethernet, I'm not sure about what you say. PHY chip needs rather
precise non spreaded clock. We ended up to feed ETH and USB phys
from fpga and routed non-spreaded clock into fpga for multiplication..
anunesgu
Just updating on this thread, according to this AR, The Zynq devices have not been characterized for spread spectrum clock inputs to the main PS clock.
https://www.xilinx.com/support/answers/66817.html
Andre Guerrero
Product Applications Engineer
