Zynq Tcl Consolw warnings
      I am using Vivado 2014.4 on Windows OS(32 BIT) ,WEB EDITION. when i configured the Zynq pS and generate the output products , at time in mine Tcl CONSOLE  I noticed following two warnings. What is this and are they need to be addressed right now or i can go ahead even with this????
1-WARNING: [BD 41-1306] The connection to interface pin /processing_system7_0/GPIO_O is being overridden by the user. This pin will not be connected as a part of interface connection GPIO_0
2-WARNING: [xilinx.com:ip:processing_system7:5.5-1] Z_system_processing_system7_0_0: The Zynq BFM requires an AXI BFM license to run. Please ensure that you have purchased and setup the AXI BFM license prior to running simulation with this block. Please contact your Xilinx sales office for more information on purchasing this license.
Aditya
2. To Use BFM you must have valid license . Warning seems correct to me
Thanks and Regards
Balkrishan
