Zynq UltraScale+ Run Block Automation popup not showing
Hi, I recently moved from Zedboard to Zynq UltraScale+ and want to build block design.
In Zynq q7 processing system, I could easily click "Run Block Automation" Pop-up, which is not showing up when I add Ultrascale+ IP into the design.
i tried
apply_bd_automation -rule xilinx.com:bd_rule:zynq_ultra_ps_e -config {apply_board_preset "1" }  [get_bd_cells zynq_ultra_ps_e_0]
which was no help.
How can I complete Run Block Automation for US+ MPSOC?
Thank you.
