Zynq Ultrascale+ Clock of S_AXI_LPD
Dear Sir,
How can I know which clock is driving the S_AXI_LPD, S_AXI_HPC, S_AXI_HP_FPD and M_AXI_HPM0_FPD ? What is the frequency of AXI clock for S_AXI_LPD, S_AXI_HPC, S_AXI_HP_FPD and M_AXI_HPM0_FPD ?
Teddy.
Tags (2)
Hi @teddywhy,
You could know that by knowing which clock is connected to the clock pin of each port:
Best regards,
Abdallah
Hi @teddywhy,
Best regards,
Abdallah
