Zynq Ultrascale+ DDR4 test problem
I'm using the ZYNQ memory test application form SDK v2018.3 on the xczu15eg. I have 8GB of SDRAM 64bits wide. I can test the first 2GB with the cache on. But the rest of the DRAM upto 8GB just hangs the test app. Works ok if I turn off the Cache. Any ideas?
did you run FSBL before running DRAM test app?
No, Do I need to build one in SDK and run it?
Do I need to do this when running in  SDK? If so how would I do this?
yes, you need to create a FSBL in SDK, then run it first.
Please refer to the following steps.
https://www.xilinx.com/support/answers/72210.html
ok i will try this. I'm using components DDR4 chips not a SODIMM bye the way
