paulleons
Zynq VIP or AXI VIP
I am starting a new design with Zynq 7000 family. I am using the latest version of the tool - Vivado 2018.2.  I noticed that for the latest version, Zynq VIP (replaced Zynq BFM) and AXI master VIP is available for free to help desingers with functional verification.
Zynq VIP provides some useful API that can be used for directly my design. The AXI VIP seems generic, also has SystemVerilog style tasks which can be used in the design as well(seems to be more recent). Both have protocol checks and assertion to check for invalid operations.
So I am wondering if there is any recommendation from Xilinx on which one to use specific to Zynq family ?
Paul
savula
HI @paulleons,
Please use the Zynq VIP in case of Zynq designs. Zynq VIP more advantages than AXI VIP in case of Zynq design and Zynq VIP is directly a part of Zynq IP.
Best Regards,
Srikanth
paulleons
Just wondering if anyone has any suggestions regarding my post earlier.
Thank you.
savula
HI @paulleons,
Best Regards,
Srikanth
