bremenoa
Zynq Z7010 / Z7020 JTAG
I recently ordered my first FPGA.  A Z-turn board from MyIR, and it's up an running.
I would like to buy a low cost JTAG for the FPGA side that support the Z7010 / Z7020 but I do not need support for the Kintex based Zynq.
The Z-turn board has the 14 pin JTAG header.
What low cost JTAG alternativs (that is not extremly slow) works with my board ?
This one looks good
https://www.digilentinc.com/Products/Detail.cfm?NavPath=2,395,1298&Prod=JTAG-HS3
pratham
Hello @bremenoa,
This should work fine with your board.
-Pratham
