Zynq ultrascale interrupt controller registers
I have started working recently in embedded C in Zynq ultrascale. I want to know the bit by bit definition details of the GICD registers , specifically GICD_SET/CLEAR Enabler0 registers. where can I get this information? It is not there in UG1085. The online Zynq ultrascale register manual says these data is there in Arm Generic Interrupt Controller Architecture Specification 2.0. But there also bit by bit definition is not there.Where can I get this information?
Thanks in advance
Shalini K
Re: Zynq ultrascale interrupt controller registers
Not in the xil_parameters.h when you create a bsd?
thanks for reply.
I will not be working with Xilinx libraries ,in Xilinx SDK. But I want to know the bitwise specification in GICD registers. Which pdf gives these details?
Thanks in advance
With regards
Shalini
If you want to skip Xilinx stuff then I would ask ARM.
Also, if that info is in the xil_parameters.h, you can just use it, it's not going to change when you use another library or compiler
