Voyager
Voyager
ZynqMP how to enable DDR Write CRC?
Could not find any by google, or in UG1085, PG201.
Is it: DDR Configuration > Other Options > Parity
Tags (3)
Re: ZynqMP how to enable DDR Write CRC?
Correct, WriteCRC will not be enabled by default.
https://www.xilinx.com/support/answers/68788.html
Can you clarify why you think you need it? It has a strong performance impact and shouldn't usually be needed in embedded memory topologies.
Voyager
Voyager
Thanks for comments, quite the opposite on use case.
We need to swap pins for DDR memory, just want to make sure Wire CRC is not accidentally enabled.
