gulong123
axi data didth converte problem
recently i met a problem about axi-3 write operation ,the question is:
i send some axi burst frome pl to ps ,and find the wready is low during the debug process.
some information :
in pl ,i receive  ethernet frames ,and divide it into several axi-busrt (in order to meet the axi-3 proctol),the awlen of these bursts are different(1~16); and i do some  axi write operations to send these burst  to ps;
ps : i use an axi data width converter ip to intercontact the  s-axi interface and the m-axi-interface is connected to the hp port
the code and the structure are as follows:
florentw
Hi @gulong123
I assume this is the same error as https://forums.xilinx.com/t5/Processor-System-Design-and-AXI/write-operation-err-when-using-a-axi-data-width-converter/m-p/1119093 right?
