can't get VDMA -> AXI stream -> video out to work
I have been trying for days to get video output on a Zedboard, but am having a lot of trouble.
VGA or DVI/HDMI, either is fine but I have had different problems with each.
I'm using the latest 14.4 tools.
I have tried to work out the relevant parts from several reference designs:
VDMA data sheet
Building a video design from scratch
Avnet HDMI FMC video design
Analog ADV7511 reference design for Zynq
The examples all seem to have a video in component, so maybe because I only want video out I have something set incorrectly, although I have tried to adjust where necessary.
So I am trying to just get the minimal parts working: VDMA, timing controller, and stream to video out.
To make it even simpler I am using standard VGA resolution, and sending the signals to the analog VGA port on the Zedboard.
The timing seems ok, I could get a display with just TPG, timing, and stream to out cores.
When the VDMA is activated, I can see action on the AXI stream bus but the AXI-stream-to-video doesn't pass anything through and it never asserts LOCKED. I have attached some chipscope plots.
I am setting up the VDMA according to the software examples, removing the s2mm parts.
The video clock is generated from an MCMM in the logic (25 MHz for VGA).
Areas that I'm not completely sure about:
fsync connections and settings
genlock setting
various master/slave settings
clock domains
I would greatly appreciate any ideas, this is starting to frustrate me!
The MHS file is attached, if that doesn't help I could attach the whole project.
Thanks!
Daniel
Hey Daniel,
Would you say that the VTC VTIMING_OUT signals look correct? I can't quite tell because I can't see vsync.
www.xilinx.com
Hi bwiec,
Thanks for your reply.
I assumed that vsync was ok because the other signals were fine... but I just tried triggering chipscope on edges and apparently it doesn't change!
I have changed the stream to out to slave mode, so I'll try and figure out what happened to vsync...
Daniel
Hello Daniel,
Were you able to rootcause this issue ? Could you please know if it was indeed Vsync problem ?
Vinesh
Hi Vinesh,
I remade the design, and Vsync was correct but I still got no output.
The only way I was able to get any output was to add a video-in-to-AXI or test pattern generator connected to the S2MM port of the VDMA, as then the VDMA settings are the same as in the example designs.
I'm sure it is one tiny setting somewhere, but with 20mins to re implement each time I haven't been able to figure out what it is.
If you figure it out, please post!
Daniel
Hi Daniel,
I have been trying several days to get video output on a Zedboard too.
I have not any output.
Please give me your MHS file where you "was able to get any output was to add a video-in-to-AXI or test pattern generator connected to the S2MM port of the VDMA".
Cherednik
Hello all,
I know there would be some one who can help me in solving the problem.
when i run the reference design
http://wiki.analog.com/resources/fpga/xilinx/kc705/adv7511
on ZEDBoard from SDK.
I see the following output on terateam.
ADI HDMI Trasmitter Application Ver R1.1.1
HDMI-TX: ADV7511 Rev 0x14
Created: Jan 24 2014 At 17:39:03
To change the video resolution press:
'0' - 640x480; '1' - 800x600; '2' - 1024x768; '3' - 1280x720
'4' - 1360x768; '5' - 1600x900; '6' - 1920x1080.
Mute audio and video.
APP: Driver Enabled
HPD changed to HI
MSEN changed to LOW
A new EDID segment was read.
DVI device.
------------------------- EDID BLOCK 0 -------------------------
Edid Version 1.3
Mon Timing:
Pixel clock = 108.0 MHz
H Active = 1280
V Active = 1024
Progressive
No stereo
Separate sync = 3
+ve VSync
+ve HSync
Mon Freq:
Min V Freq = 56 Hz
Max V Freq = 85 Hz
Min H Freq = 30 KHz
Max H Freq = 81 KHz
Mon Name: 170T Digital
Mon Serial: H4URA09215
Edid extensions blocks: 0
########################### EDID END ###########################
MSEN changed to HI
APP: Changed system mode to Transmitter
Un-mute audio and video.
MSEN changed to LOW
APP: Changed system mode to Disconnected
can any one suggest what does it mean?
how can i see some image or video?
Thanks in advance.
Hamid
