cant find microblaze_mcs_data2mem
hello,
i do my first steps with the microblaze mcs and got a problem...
i work with a tutorial and get to the point where i have to type the following in the tcl-console:
microblaze_mcs_data2mem /workspace/hello_world_0/debug/hello_world_0.elf
and get this error message: invalid command name "microblaze_mcs_data2mem"
i took a look in the folder where microblaze_mcs_data2mem should be. but it isnt there.
i work with ise 14.2. what can i do?
thanks for your help
SOLVED!
It was Reset pin from Microblaze...I didn't put it in constrait file.
Best regards.
Did you first "source" the tcl file with "source microblaze_mcs_setup.tcl" at the command prompt?
It has to be done every time you start the tools.
Göran
Hey Göran,
thank you for this fantastic hint.
That was the problem.
Does anyone know how to integrate .elf file from SDK into .bit file in ISE?
I followed tutorial where I implemented Microblaze processor and VHDL top module. I connected everything and when I try to downlaod .bit file to FPGA nothing happens. Like there is no C code to be run.
Tutorial link:  http://ece.wpi.edu/~rjduck/Microblaze%20MCS%20Tutorial%20v5.pdf
You can use Data2Mem command to update the .bit file (from ISE) with the .elf (from SDK)contents:
For example, to update my.bit with code.elf based on my.bmm, use the following command in ise command prompt:
data2mem -bm my.bmm -bd code.elf -bt my.bit -o b new.bit
This will create new.bit, which is initialized with code.elf file.
Thank you for quick reply. I tried the command and it creates new .bit file but again nothing happens. I have been working all day on this problem... do you have any suggestion for a tutorial maybe I missed some steps.
P.S. I used microblaze_mcs_bd.bmm from a ipcore_dir folder.
Thank you, best regards.
SOLVED!
Best regards.
