se17828
compactFlash sp605
Just a quick question, can the compact flash actually be re-programed (save new configuration files inside off it) with only the SP605 board or do I need a PC adapter to plug it in my computed?
joshual
You can use CF card adapter to access the CF Card.
Or you can also use the sysace() function provided by EDK to control the CF Card
