configure the register of S2MM affect MM2S?
Hi:
    I use the MM2S channel of VDMA  send  the data in ddr to HDMI interface.I can see what I write in the ddr on the monitor. And then I want test the S2MM channe.I set the start address of S2MM in another  region of ddr.But when I start  the S2MM channel  by set the S2MM  Vertical Size Register,I found that there is nothing on my monitor.
configure the register of S2MM can affect MM2S? This my c code initialize VDMA.
//S2MM
XAxiVdma_WriteReg(XPAR_VIDEO_PIPE_1_AXI_VDMA_1_BASEADDR, 0x30, 0x4); //reset
XAxiVdma_WriteReg(XPAR_VIDEO_PIPE_1_AXI_VDMA_1_BASEADDR, 0x30, 0x8); //genlock
XAxiVdma_WriteReg(XPAR_VIDEO_PIPE_1_AXI_VDMA_1_BASEADDR, 0xAC, 0x11000000);
XAxiVdma_WriteReg(XPAR_VIDEO_PIPE_1_AXI_VDMA_1_BASEADDR, 0xAC+4, 0x12000000);
XAxiVdma_WriteReg(XPAR_VIDEO_PIPE_1_AXI_VDMA_1_BASEADDR, 0xAC+8, 0x13000000);
XAxiVdma_WriteReg(XPAR_VIDEO_PIPE_1_AXI_VDMA_1_BASEADDR, 0xA4, 1920*4);
XAxiVdma_WriteReg(XPAR_VIDEO_PIPE_1_AXI_VDMA_1_BASEADDR, 0xA8, 0x01002000);
XAxiVdma_WriteReg(XPAR_VIDEO_PIPE_1_AXI_VDMA_1_BASEADDR, 0x30, 0x3);
// XAxiVdma_WriteReg(XPAR_VIDEO_PIPE_1_AXI_VDMA_1_BASEADDR, 0xA0, 1080);
When I add this sentence above it can't work.
//MM2S
XAxiVdma_WriteReg(XPAR_VIDEO_PIPE_1_AXI_VDMA_1_BASEADDR, 0x0, 0x4); //reset
XAxiVdma_WriteReg(XPAR_VIDEO_PIPE_1_AXI_VDMA_1_BASEADDR, 0x0, 0x8); //gen-lock
XAxiVdma_WriteReg(XPAR_VIDEO_PIPE_1_AXI_VDMA_1_BASEADDR, 0x5C, 0x10000000);
XAxiVdma_WriteReg(XPAR_VIDEO_PIPE_1_AXI_VDMA_1_BASEADDR, 0x5C+4, 0x107E9000);
XAxiVdma_WriteReg(XPAR_VIDEO_PIPE_1_AXI_VDMA_1_BASEADDR, 0x5C+8, 0x10FD2000);
XAxiVdma_WriteReg(XPAR_VIDEO_PIPE_1_AXI_VDMA_1_BASEADDR, 0x54, 1920*4);
XAxiVdma_WriteReg(XPAR_VIDEO_PIPE_1_AXI_VDMA_1_BASEADDR, 0x58, 0x01000000+1920*4);
XAxiVdma_WriteReg(XPAR_VIDEO_PIPE_1_AXI_VDMA_1_BASEADDR, 0x0, 0x83);
XAxiVdma_WriteReg(XPAR_VIDEO_PIPE_1_AXI_VDMA_1_BASEADDR, 0x50, 1080);
