cyclic BD interrupts
I am trying to set up an AXI DMA fed by a Stream FIFO in cyclic SG mode and have some questions as early attempts to get this working are evading me.
I have a Zynq system set up with custom IP feeding data to a Stream Fifo in Packet mode. My custom IP periodically strobes TLAST for one Stream clock cycle. I have the DMA core configured for SG, non-Micro, RX only.
I have SW set up in XSDK with a simple application leveraged from the sg interrupt example. I get one interrupt, I see the data transferred correctly for 1 packet and then nothing. The ring is set up using the example configuration for packet length, interrupt coalesce, number of packets and bds per packet.
I have ILA in the design and I see the s2mm_introut assert and my ISR fires, shortly thereafter the IRQ deasserts correctly and reasserts again but the second assertion does not result in my ISR firing.
I have checked the S2MM_STS register all is well - no errors, not halted not idle.
What I really need to be able to do is set up for 2 large buffers in cyclic mode - i.e. set up and start, DMA runs forever ping-ponging between the 2 buffers and interrupting at each buffer completion. It seems like this should be possible. I'm guessing my problem is not completely understanding how to make a buffer transaction complete cause an interrupt on each buffer completion or possibly do interrupts need to be reenabled after each ISR?
Is there an example project somewhere that I can use a s reference to get this unblocked for me?
Any help/advice appreciated ---
Community Manager
Community Manager
We don't have an example design for this. But you can refer to https://forums.xilinx.com/t5/Embedded-Processor-System-Design/AXI-DMA-Cyclic-BD-not-working/td-p/722784 for some guidance.
