tarek.1982
displaying a video from a vga video input
When I want to generate the bitstream, I found this error.
ERROR:Place:713 - IOB component "fpga_0_DDR2_SDRAM_DDR2_DQ_pin<13>" and IODELAY
   component
   "DDR2_SDRAM/DDR2_SDRAM/mpmc_core_0/gen_v5_ddr2_phy.mpmc_phy_if_0/u_phy_io_0/g
   en_dq[13].u_iob_dq/u_idelay_dq" must be placed adjacent to each other into
   the same I/O tile in order to route net
   en_dq[13].u_iob_dq/dq_in". The following issue has been detected:
   Some of the logic associated with this structure is locked. This should cause
   the rest of the logic to be locked.A problem was found at site IODELAY_X0Y56
   where we must place IODELAY
   DDR2_SDRAM/DDR2_SDRAM/mpmc_core_0/gen_v5_ddr2_phy.mpmc_phy_if_0/u_phy_io_0/ge
   n_dq[13].u_iob_dq/u_idelay_dq in order to satisfy the relative placement
   requirements of this logic.  IODELAY
   n_dqs[0].u_iob_dqs/u_iodelay_dq_ce appears to already be placed there which
   makes this design unplaceable.
ERROR:Pack:1654 - The timing-driven placement phase encountered an error.
ERROR:Xflow - Program map returned error code 2. Aborting flow execution...
make: *** [__xps/vga_kit_routed] Error 1
ERROR:Place:713 - IOB component "fpga_0_DDR2_SDRAM_DDR2_DQ_pin<13>" and IODELAY   component   "DDR2_SDRAM/DDR2_SDRAM/mpmc_core_0/gen_v5_ddr2_phy.mpmc_phy_if_0/u_phy_io_0/g   en_dq[13].u_iob_dq/u_idelay_dq" must be placed adjacent to each other into   the same I/O tile in order to route net   "DDR2_SDRAM/DDR2_SDRAM/mpmc_core_0/gen_v5_ddr2_phy.mpmc_phy_if_0/u_phy_io_0/g   en_dq[13].u_iob_dq/dq_in". The following issue has been detected:    Some of the logic associated with this structure is locked. This should cause   the rest of the logic to be locked.A problem was found at site IODELAY_X0Y56   where we must place IODELAY   DDR2_SDRAM/DDR2_SDRAM/mpmc_core_0/gen_v5_ddr2_phy.mpmc_phy_if_0/u_phy_io_0/ge   n_dq[13].u_iob_dq/u_idelay_dq in order to satisfy the relative placement   requirements of this logic.  IODELAY   DDR2_SDRAM/DDR2_SDRAM/mpmc_core_0/gen_v5_ddr2_phy.mpmc_phy_if_0/u_phy_io_0/ge   n_dqs[0].u_iob_dqs/u_iodelay_dq_ce appears to already be placed there which   makes this design unplaceable.  ERROR:Pack:1654 - The timing-driven placement phase encountered an error.ERROR:Xflow - Program map returned error code 2. Aborting flow execution...make: *** [__xps/vga_kit_routed] Error 1
Thanks for help
eteam00
Professor
Professor
Not enough information.
SIGNATURE:
Summary:
