dqs_ibuf does not have IOSTANDARD specified
I'm having this error:
ERROR:LIT:600 - IOBUFDS symbol
   "DDR2_SDRAM/DDR2_SDRAM/u_ddr2_top/u_mem_if_top/u_phy_top/u_phy_io/gen_dqs[0].u_iob_dqs/gen_dqs_iob_ddr2.u_iobuf_dqs" (output
   signal=DDR2_SDRAM/DDR2_SDRAM/u_ddr2_top/u_mem_if_top/u_phy_top/u_phy_io/gen_d
   qs[0].u_iob_dqs/dqs_ibuf) does not have IOSTANDARD specified. Map is unable
   to generate a default IOSTANDARD for IOBUFDS, one has to be explicitly
   provided.
In the attachments you can find the UCF.
Any idea?
Instructor
Instructor
what are the IO pins (location, signame) associated with the IOBUFDS IOs?
You might want to open PLANAHEAD app and check for "unassigned" pins.
SIGNATURE:
Summary:
