emacps PHY detect_phy() always returns phy_reg = 0xFFFF
I used baremetal to run echo sample application but emacps PHY detect_phy() always returns phy_reg = 0xFFFF.
What is possible problems  with this?
My board is custom board with KSZ9031 PHY.
Re: emacps PHY detect_phy() always returns phy_reg = 0xFFFF
Hi @tuan.nhanh ,
It means the PHY id value is not valid PHY address.
Praveen
Tks @pvenugo
I knew it is not valid, but what is the problem with it.
It is ok with Linux but bare-metal.
Please suggest me what should I check.
Is it HW or SW problem?
Best regards
