error for ZYNQ 7Z045 device for planahead IO pin planning
i am designing a custome ZYnq board for my application using ZYNQ 7z045 device. using ISE and XPS i designed the internal hardware configuration.for IO pin planning i selected IO pin planning using Planahead (post systhesis).
when planahead launches it is giving error messge as follows i dont know what to do.
ERROR: [Device 21-41] Device part file is invalid: [C:/Xilinx/14.7/ISE_DS/PlanAhead/data\./parts/xilinx/zynq/zynq/xc7z045/xc7z045.xng]
i am using ISE 14.7.
please help out of this as soon as possible.
Tags (2)
Can you try this out?
In Planahead, create a IO planning project with this target part ZYNQ 7z045 and see if it succeeds.
Deepika.
Deepika.
sorry for the late reply.,
i tried that also., but it is also giving same error.
but i  generated same design in vivado HLS it is working there.
i think there is problem in part library in ISE 14.7.
whether you also facing same issue?
I tried creating an IO planning project in Planahead 14.7 using the same part. This went on fine.
looks like some install issue. Can you try using a different machine and see if that helps?
Deepika.
Deepika.
Quick question, are you using Webpack for the ISE Design Suite?
--Hem
hi hem.,
i am using system edition of ISE 14.7
i went to the root directory of the error. i found that the .xng file is of 0KB size.
i think i have to install once again.,
Yes, please re-install ISE and this time after downloading the ISE, before installation verify the checksum of download.
Let us know if this is not fixed even after re-install.
Deepika.
Deepika.
