mdvankar1990
error while using math.h library in zynq 7000 zc 702 board application programme.
hi guys,
I m trying to simple program.
#include <stdio.h>
#include <math.h>
#include "platform.h"
int main()
float a,b,c,d;
a=2.3;
b=2.5;
c=a+b;
d=cosf(c);
in this  i am getting "undefined reference to cosf ".
in this function,
instead of using variable c, if i use some value it gets run.
like cosf(2.5);
but using variable gives above error.
solution??
ericv
You need to link with the math library,
In the linker setting, add "m" (without the quotes) in the library window.
The reason it works when you put a constant is the compiler replaces cosf(2.5) by the resulting value.
ericv
