yang0
fifo+dma+ddr problem
I have a system that transfer 256bits data width steam data to 512bits ddr4, and steam data assert tlast every 16*256bits.
axi dma configuration as follow,direct mode, interrupt , setting length enough.but work badly.
one problem is s2mm interrupt asserted interval when transfer 16*256,1*256,16*256,1*256 data.expectly all is 16*256.
another is ddr data , lower 256bits ok. but higher 256bits filled with last 256bits data.
Any suggestion? thanks.
yang0
add 2 pic to show the problem
