mivadera
from PL to PS
Hi guys,
Is there a way to send data from PL to PS using interrupts acknowledgment in axi lite?
Tags (3)
stephenm
Yes, you can add a master port in the PL to the PS via the slave interfaces. if you want to send data, then just use a CDMA with interrupt connect to the scugic
stephenm
