sergiuutcn
genertating x<driver_name>_g.c files
I am in the process of writing an SDK driver for a Vivado IP Core and I am trying to follow the Xilinx structure/guidlines. While trying to write the initialization function, I ran into the following issue. IP Cores from Xilinx like UART, Timers or even the old EDK drivers all carry a _g.c file which is somehow generated by Vivado or SDK. I found that these IPs have a TCL file which is responsible for generating the _g.c file.
My question is where do I have to actually tell the system how to create the _g.c file that I need for my IP? Do I have to create a TCL file like the one I found for the Timer IP Core (tmrctr.tcl)? If so, how do I inform the system about the existence of that file? Do I have to add it to the Vivado IP Packager?
Thank you,
Sergiu
pvenugo
Hope these links of creating driver for custom IP and software driver will help you.
https://silica.avnet.com/wps/wcm/connect/e2612871-ffdd-470e-b355-f12e0f570395/SILICA_Xilinx_Designing_a_custom_axi_slave_rev1.pdf?MOD=AJPERES&CVID=liIcQoZ&CVID=liIcQoZ
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug1138-generating-basic-software-platforms.pdf
Praveen
balkris
check these links it may help you
https://forums.xilinx.com/t5/Embedded-Development-Tools/SDK-include-custom-IP-peripheral-driver-files/td-p/250464
https://forums.xilinx.com/t5/Embedded-Processor-System-Design/Device-drivers-for-IP-cores-in-Vivado/td-p/383753
Thanks and Regards
Balkrishan
sergiuutcn
I read the threads that you provided and unfortunately I found no mention of the _g.c file I was asking about.
I don't have any issues with exporting driver files or old driver versions like the ones discussed in those forum posts. What I am interested in is generating the *_g.c file which will become part of the IP core driver. The only place where I found that the file is mentioned is in this pdf: https://forums.xilinx.com/xlnx/attachments/xlnx/NewUser/23544/1/xilinx_drivers_guide.pdf.
At page 5 under "Example file names" you can find the file mentioned as "Generated file controlling parameterized instances". I want to know the procedure for obtaining this file for my custom IP core.
Sergiu
pvenugo
Praveen
