hard reset to microblaze and fpga
sir
i am working on KC705 board. i have integrated fpga and microblaze module.i want that when i press cpu_reset button on board both fpga and microblaze module should be reset .
in my case after pressing reset button fpga is resetting but microblaze is not resetting and giving error on hyperterminal
xps_ethernetlite driver not present
pkt dropped, no space,
plz help me to solve this problem...
thanks
shweta
thanks
shweta
space appplication center
ahmedabad
Hi ,
      How do you give reset signal to microblaze ??
If you using the module proc_sys_reset, it will have an reset input which will reset MicroBlaze and the rest of the peripherals.
Göran
microblaze is getting reset by pro_sys_reset module and pro_sys_reset module is connected by push button on board.
even i have try by changing the push button on board but same result is coming....
thanks
shweta
ahmedabad
yes
in my xps design proc_sys_rst is resetting microblaze and other pheripherals but after pushing the hard button same error is coming on hypeterminal
configuration error : xps_ethernetlite driver not present
packet dropped, no space
i am frustating that why this error is coming???????????//
thanks
shweta
ahmedabad
    Are you giving two different hard resets, one for fpga and one for microblaze ?? . first check your design if the fpga and microblaze needs a synchronous reset . If so, provide the same reset for both .Try routing a signal from fpga hard reset to proc_sys_rst of microblaze. Hope this helps.
 -San
fpga reset and microblaze reset is connected to the same reset pin.
in my design microblaze reset is connected to RESET pin "AB7" in ucf. in fpga design same RESET pin is using for reseting the fpga modules..
thanks
shweta
ahmedabad
If your microblaze reset is connected to a physical pin, then microblaze must get reset. Check your design or give the physical hard reset to fpga and take a signal from fpga reset and pass to microblaze reset .
-San
