how to change zhe M_AXI_HPM0_FPD ID_WIDTH of ZYNQ UltraScale+ MPSoC
The default value of  M_AXI_HPM0_FPD ID_WIDTH is 16. Could you please let me know how to change zhe value.
Tags (2)
HI @zhmm
It is fixed to 16 as per table 35-1 of UG1085 so you cannot change it
Florent
HI @zhmm
Florent
