yeting
how to display "Hello world" on monitor and LCD
hello,everyone,i have some troubles  with ml501 board.i want to display "hello world" on monitor through DVI connector and display "hello world"on LCD too.but i can't find the doucument about how to use these devices,could you give me some advices?thank  you very much!!!
mariano_severi
to handle the DVI output port, you should add the xps_tft peripheral. You can found usefull information here : http://www.xilinx.com/products/boards/ml501/ml501_11.1_1/docs/ml501_bsb_std_ip_addition.pdf
The xps_tft comes with api functions and also example routines to write messages to the output; you'll find these in the appropriate directory in the directory sw\XilinxProcessorIPLib\drivers\tft_v2_00_a\examples under your EDK installation
 Mariano
yeting
thanks for your help,en,what do you think  about LCD?do you have some idea?
mariano_severi
for the LCD you can use a xps_gpio. In the reference design http://www.xilinx.com/products/boards/ml501/ml501_11.1_1/files/ml501_bsb_std_ip.zip
you can find how to do this. In the sw\standalone\lib\src\lcd_char directory there's also a lcd.c file with simple API to write data to the display. Regards
 Mariano
