04-07-2017 05:34 AM
I know how to import.but how to export?
04-07-2017 08:19 PM
@christine1225 xml file comes from an xps export. Basically the flow is you generate a configuration in xps in the gui and then you can export this configuration and import it to another project etc.
04-07-2017 02:04 PM
@christine1225 I don't think Vivado has an export facility to create xml files for xps to read.
04-07-2017 07:12 PM
Thank you.
If I want to import xps settings, do I need to write the xml on my own myself?
where does the xml file come from?
04-07-2017 08:19 PM
02-27-2019 10:15 AM
I have not been able to obtain any useful effect by using Import XPS Settings, or the other work arounds posted in this forum.
What has worked for me for the task of capturing the IP customization settings for the Zynq processing system IP (and really for any of the IPs), from one design in a manner where you could re-apply these to a later design, is the following:
Do
File -> Export -> Export Hardware
Pick a directory, for symplicty, choose Local to Project
In the project directory on disk, if your design is called design_1, find the file design_1.sdk/design_wrapper.hdf
Alternatively, if your hardware team has given you an exported hardware file, import this into SDK. If the design was called "design_1" (which is the default name) then open the directory design_1_wrapper_hw_platform_0.
In that directory will be a file called system.hdf
This file is actually a zip file, open it using gzip or 7z
File the file design_bd.tcl in that zip file, or xxxx_bd.tcl if the design is called xxxx
Open the file, and for the Zynq settings. search for processing_system7
Observe tcl code that looks like the below. The section "set_property -dict [ list " through to the end is the golden nugget.
# Create instance: sys_ps7, and set properties
set sys_ps7 [ create_bd_cell -type ip -vlnv xilinx.com:ip:processing_system7:5.5 sys_ps7 ]
set_property -dict [ list \
CONFIG.PCW_ACT_CAN_PERIPHERAL_FREQMHZ {10.000000} \
CONFIG.PCW_ACT_DCI_PERIPHERAL_FREQMHZ {10.158730} \
CONFIG.PCW_ACT_ENET0_PERIPHERAL_FREQMHZ {125.000000} \
CONFIG.PCW_WDT_PERIPHERAL_ENABLE.VALUE_SRC {DEFAULT} \
CONFIG.PCW_WDT_PERIPHERAL_FREQMHZ.VALUE_SRC {DEFAULT} \
CONFIG.PCW_WDT_WDT_IO.VALUE_SRC {DEFAULT} \
] $sys_ps7
Copy this statement into a file, called say, zynq_settings.tcl, and then change the $sys_ps7 at the end to
[get_bd_cells processing_system7_0]
Your file will look like the below (except the '...' will have many lines setting up many things)
] [get_bd_cells processing_system7_0]
Now create a new design in Vivado
Create an instance of the Zynq processor
( Add IP, type zynq, and select the one that shows up)
Then type source zynq_settings.tcl
in the tcl window, and these settings will be imported.
You will likely get some errors like:
CRITICAL WARNING: [BD 41-1276] Cannot set the parameter PCW_SINGLE_QSPI_DATA_MODE on /processing_system7_0. Parameter does not exist
as the design you are building does not have the QSPI selected yet.
