how to save the result which SDK get from the Zynq?
I want to test my IP core on Zynq in standalone mode in SDK. There may be many results printed in the Console Window. I want to save the results in file when a "printf" instruction invoked. How can I make it?
Thanks very much!
If you are using a hyperterminal program you can do a capture as shown here.
http://www.engr.sjsu.edu/ciscolab/handouts/save.htm
--Hem
--Hem
Thanks very much. It works.
