how to transfer video data with lwIP bare metal ethernet
- Vivado, SDK: 2017.4
- Device: Zynq-7000
details
I have image data stored in VDMA frame buffer that I'd like to transfer to my PC for debugging purposes.
I chose 1GbE as interface for this, on the PS. I am able to transfer simple commands via HTTP POST messages between client and host and individual image frames. Performance is currently not optimized.
The size of my ethernet frame buffer is 1kB. To overcome this limitation I am pointing to the image frame buffer, instead.
Since lwIP is taking care of packet splitting to meet MTU I am assuming that I can provide any number of bytes to be send using tcp_write().
// create a HTTP header POST message, store in memory right before frame
len = generate_http_header((char *)(frameBufferStartAddress-headerLength), "js", length);
// update length of payload, in bytes
len += framelength;
// create TCP packets from bytes in memory
if (tcp_write(pcb, (char *)(0x0A000000-headerLength-3), len, 1) != ERR_OK) {
    xil_printf("error writing http POST response to socket\n\r");
    xil_printf("http header = %s\r\n", buf);
    return -1;
Doupts
This approach worked for me only for a small amount of data, relatively spoken. tcp_write() failes to send more data at once. Is it a good practive to call tcp_write() multiple times, if so which size should I choose?
Documents read:
- XAPP1026
- ug585
- https://stackoverflow.com/questions/15384518/how-many-bytes-can-i-write-at-once-on-a-tcp-socket
Can you provide me suggestions about my current approach or provide helpful references to solve such problems.
thank you
Re: how to transfer video data with lwIP bare metal ethernet
Hello @theultimatesource,
call the tcp_write()  function for multiple times and transfer around 1400 bytes in each transfer.
Best Regards,
Srikanth
Best Regards,
Srikanth
