zhangjun_beijing
how will the address increase when use narrow size to write data to PS ddr3 through s_axi_hp interface?
I use zynq bfm ip to simulate s_axi_hp interface.
s_axi_hp is 64 bits size. I set awsize is "001",  means 16 bits size. I write data to ps side ddr3, then read back. I found awsize is not valid, 64 bits size is only useful.
I want to know whether zynq s_axi_hp bus support narrow size mode?
thanks
savula
Hi @zhangjun_beijing ,
Yes, the narrow burst on S_AXI_HP port is suuported. please check whether it is enabled or not in your design:
Best Regards,
Srikanth
savula
Best Regards,
Srikanth
zhangjun_beijing
hi,
I use zynq_processing_system_bfm ip to simulate. This ip have not this config option. I don't know if zynq_processing_system ip can simulate. I will try.
thanks.
savula
I am able to see the narrow burst support for Zynq also. please check below image:
Best Regards,
Srikanth
