kikibillel52
implement two different systems (one with floating point library and one without)
i want to have two system (for example, CPU 1 and CPU 2) doing the same calculation process. One of them working with floating-point arithmetic and other without floating piont arithmetic. The idea then is to do a comparaison between the two systems regarding the precision of calculations in each systems (results of both systems).
Or for example, implement a vhld block (multiplication function) in cyclone V through NIOS or ds-5 debugger. The ARM core working of course with floating point library, and execute in parallel same operations (multiplication function). At the end, both results need to be compared in some way.  Is it possible to do this kind of implemetation and what are the possible ways?
Thanks in advance.
bruce_karaffa
Do you realize that this is a Xilinx forum and the CycloneV is an Intel chip?
