muuu
interface in Zynq7020
we want one usb2.0 device and one usb2.0 host in zynq7020, is it possible?
Thank you!
jg_bds
Yes. The controllers behind the two interfaces are independent. They can be configured as different types at the same time.
-Joe G.
jg_bds
The Zynq 7020 can be configured to support 2 USB ports at the same time. From the TRM (UG585):
-Joe G.
muuu
Yes, there are two usb ports, when one port is configured as device, Can the other port be configured as host?
Thank you,
Kerb
jg_bds
-Joe G.
muuu
Thank you!
