libeswpm/test_aux.h not found when compiling the ZU+ Example - Deep Sleep with Periodic Wake-up
I am trying to test Zynq UltraScale+ MPSoC Design Example - Deep Sleep with Periodic Wake-up that you can find in this link
http://www.wiki.xilinx.com/ZU%EF%BC%8B+Example+-+Deep+Sleep+with+Periodic+Wake-up. In this exemple, there are two applications: one for APU and the other for RPU (the C code of applications is provided). The problem is that I can not find the "libeswpm/test_aux.h" which is needed by the apllications. I think it includes the definition of this functions :IpiWaitForAck(), SyncWaitForReady(), PmTestInit() and IpiWaitForInitSuspend(). I am working with vivado, SDK and Petalinux versions 2016.4 on ZCU 102 Board. So could you please help me to find this file so I can compile the apllication?
I have the same issue with this library.  Is there any solution?
Chris
This issue is taken up by Xilinx engineers on priority and presently working to find solution.
This post will be updated once we have root caused and have workaround or solution.
Hi @cfbyton @fahem,
Have you tried this method ? https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842048/ZU+Example+-+PM+Hello+World
I got this library supporting files and able to build application for apu_application.c mentioned in the previous wiki.
I am attaching my workspace here. You can replace your application in hello/src/ and build.
If you see any dependencies like libeswpm/test_aux.h then replace them with "test_aux.h" as I have copied all the dependent files in hello/src/
Best Regards
Kranthi
