doner_t
low datarate has been read from DDR3 of Xc7Z020 processors
We have measured the Bandwidth of the DDR3, via basic write-read test, that is connected to the PS side of Zynq XC7Z020.
DDR3 specs are 32- bit, 533 MHz. But BW results are seen nearly 120 MB/s . It is too low...Why is this BW seen so low ?
There are also another DDR3 bank that is connected to the PL side of XC7Z020 . But how can I write PS side DDR3 from the PL side ?
TD
Tags (3)
vsrunga
@doner_t
For Q1, Performance depends on many factors like your address pattern, memory timing parameters, refresh etc.,
You can run a simulation with your address pattern and calculate the effective bandwidth and determine the actual overhead that the controller is imposing.
For Q2, below links may help you
http://www.xilinx.com/support/answers/53320.html
http://zedboard.org/content/how-access-data-ddr-ps-side-pl-part
https://forums.xilinx.com/t5/Xilinx-Boards-and-Kits/PL-DDR-in-ZC706/td-p/331397
-Vanitha
vsrunga
@doner_t
-Vanitha
