jdcummin
manual MicroBlaze MCS flow
I wish to use MicroBlaze MCS to do some simple control functions using the following flow outline:
  1. Generate MicroBlaze MCS IP with Vivado "Manage IP".
  2. Write C code and compile. It doesn't matter to me if I use SDK or command line tools to do this step.
  3. Instantiate MicroBlaze in my VHDL and specify BRAM contents.
  4. Simulate the design in ModelSim.
  5. Build the design in Vivado by adding my VHDL top level and the MicroBlaze .xci file.
Is this possible?
John
