vinogradov_rus
memcpy problem with Zynq
I'm using SDK 2015.1 and have a problem with memcpy() with Zynq SoC
If I want to copy
src=0x4000 04ba - AXI MIG memory
DST = 0x0020 0030  - PS DDR3 memory
LEN = 1460
memcpy(DST,SRC,LEN);
System fault in Xil_DataAbortHandler. It occures because of unaligned AXI DDR3 addr. So next I write some wrapper, which check src addr, align it to 4 and then I launch
src=0x4000 04bC // Aligned to 4
DST = 0x0020 0032  // Aligned to 2
LEN = 1460 // Left the same to exclude length problem
And now the same problem is with DST addr. It isn't alligned and application falls down.
I can use memmove or just for-loop to reduce this problem, but it fall down the speed.
What's the right way to solve this problem?
