microblaze on zynq ,how to boot on sd card?thank you
hello .
i am put a microblaze on the zynq pl,
microblaze run bear metal program,arm ps0  run bear metal program。i reference  xapp1093。
i can't merge microblaze elf file into bitstream file.
can anybody give me some suggestion ,thank you!
Re: microblaze on zynq ,how to boot on sd card?thank you
when i am merge fsbl+.bit+ps0.elf into BOOT.BIN,it work.
Yes, you can create binary file to boot from SD card.
In the BIF file you may see the order of files to create .BIN file.
FSBL.elf
.bit
application .elf
Praveen
