problem in accessing ps ethernet through sfp in zcu102(revision 1.0 and part no. xczu9eg-ffvb1156-2-i) evm.
Actually i am using ZYNQ Ultra+ MPSoC ZCU102 EVM for project xapp1306 in which i want to access PS ethernet using SFP ->pcs,pma/sgmii ->GEM0, but i m not able to do pinging in teraterm. it is showing like this-
                                                 -------lwIP TCP echo server------
                                       TCP packet sent to port 6001 will be echoed back
                                                      start PHY autonegotiation
                                          waiting for PHY to complete autonegatiation
i am able to do generate bit stream, export to hardware,program to FPGA, lunch SDK and build and debug the design.
done led, SW13 has 8 led in which DS38,DS40,DS43,DS44 is glowing. other led's is off.
I thought the problem in SDK side means PS side in .c files.
so plz share your knowledge to help me.
I am using zcu102 evm with part no. xczu9eg-ffvb1156-2-i and board revision 1.0
Re: problem in accessing ps ethernet through sfp in zcu102(revision 1.0 and part no. xczu9eg-ffvb1156-2-i) evm.
Could you please check the with the 100Mbps? force speed mode to 100 Mbps and test it again.
Try to use the below patch: https://www.xilinx.com/support/answers/71295.html
Best Regards,
Srikanth
Is the correct GT ref clock getting generated? Should be 156.25Mhz.
You can use the scui tool to check your clocks on the zcu102
This one tried. Still we could not ping.  We are getting following message on teraterm
waiting for Link to be up; Polling for SGMII  core Reg
get_IEEE_phy_speed() : Invalid speed bit value, Defaulting to speed = 10 Mbps
What are your host settings?
My Host settings are:-
IP address 192.168.1.12
Subnet Mask :- 255.255.255.0
Gateway :- 192.168.1.1
Ethernet Link Speed :- set as  autonegotiation
My Board settings are:-
IP address 192.168.1.10
Hi @vikaskanha ,
PS GEM is 1G speed.
Please check if you have - 125MHz for PS GEM.
That is the reason link is not up.
Praveen
