problem in axi
Hi all
  the master support 4 outstanding write transcation, (ex:support 4 awid)
the master  can not send the fifth write transcation if the first four brsps are not received ?
Am i correct?
@tomy222,
The master can make as many requests as it wants.
If the slave isn't ready to receive them, then it needs to lower the respective READY signal(s).
Dan
Thanks for reply
if the master sends four write transcation with awid(0,1,2,3), the slave still not send the brsp to master.
is it permitted that the master send the fifth transcation (awid is 0 again), even slave don't response four brsp ?
the slave will response two same bid(two bid is 0) to master later.
therefore, the master can not identify responses from two same bid
Is it permitted?  Absolutely!  The master is able to identify them because they are required to come back in order.  The first BID = 0 response must be for the first AWID=0 request, and the second BID=0 response for the second AWID=0 request.  Remember, the slave can reorder transactions all it wants save within a given ID.  Within a given ID, transactions must be returned in order.
Dan
