problem to write program in SDK for interrupt handling
hello everybody
I am doing experiments with virted 6 based ML605 board. I want to generate an external interrupt for microblaze when any on board push button is pressed.
but I am getting confuse to write exact program in SDK for this. i am confuse because there are different functions to initilize, register, connect,enable interrupts
XIntc_Initialize and XIntc_Connect
Xintc_RegisterHandler
microblaze_register_handler
XIntc_Enable
Xintc_mIntrEnable
XGpio_interruptEnable
XGpio_GlobleEnable
etc so many different functions
I dont know which one to use where and when?
please help
There is one example document that can help you generate an interrupt using a push-button as an external interrupt.
Check this PDF
http://forums.xilinx.com/xlnx/attachments/xlnx/EDK/22898/1/Interrupt_debug.pdf
--Hem
