problem with TDATA widths in AXI4 Stream Broadcaster
In Vivado 2014.2 the AXI4 stream broadcaster seems to have a tdata width on the output that is twice what it should be. Is this correct or is it a bug?
Most IP Integrator IP will automatically infer data widths from the cores driving them and propagate that to the output types. Try hooking the core into your system and see if it still is the same.
www.xilinx.com
I met the same problem.
Same problem. All of the output ports are twice the width that they should be.  I've tried leaving the settings on 'auto' and then hooking up the ports but they don't change. This is version 1.1 of the IP and I'm using Vivado 2014.2
I'm getting something similar.   Perhaps I've missed something but I can't see how this block is even supposed to work at all?
It's not just the outputs (m_axis drivers) that are doubled, it's the input too for m_axis_tready.   However the doubling on this tready signal (only) is accounted for inside the block - looking at the synthesis, the two m_axis tready signals are AND'ed together and used to drive the s_axis tready.  In other words the broadcaster block only signals upstream that's it's ready when all of it's children are ready, this part makes perfect sense.
But the tlast, tuser etc. are different.   Each of these signals comes in from s_axis as a single signal input. The outputs to m_axis however are vectors, the doubling mentioned, and I suspect is actually one bit per output m_axis port.  But:  each s_axis signal is just wired straight to the first bit (only) of the m_axis output, meaning that it connects to the first child m_axis block only!  See the blue highlighted signals in the screenshot attached.  The other bits in the vector are just optimised away and tied low, so nothing works.
Can someone from Xilinx please step in and confirm how exactly this block is supposed to be used, perhaps an example or testbench?  The docs for this (in the AXI stream suite) or the similar AXI Video Broadcaster don't have any detail of what is supposed to happen with all these signals.
 Screenshot from 2015-04-15 11:16:44.png
Year and no answer... So Axi-Broadcaster is just "AND" for tready signal and thats all?
I realized that by checking the pin/interface properties in the block design:
consider S[15:0] => ( M[15:0] = M00, M[31:16]=M01 ), the 16 bit input is duplicated into one LSB/MSB 32 word, which appears as two interfaces /M00 and /M01.
gw.
Embedded Systems, DSP, cyber
No, it's not just that. The TVALIDs for each master also need to be adjusted. So its:
1) S_READY = M_READY_1 & M_READY_2
2) M_VALID_1 = S_VALID & M_READY_2
3) M_VALID_2 = S_VALID & M_READY_1
This deals with the case where one master is valid and the other isn't. Without #2 and #3 included, the valid master will see an asserted valid and an asserted ready, so it'll think it's a valid databeat. But it isn't, because the other master isn't ready. So it's necessary to drive the valid low when the opposite master isn't ready to deal with this case.
I encountered similar issues in 2017.4
Also in 2018.2
I have ran into slightly different issues regarding data width from the broadcaster. The simplest solution for me was to set the data width manually instead of relying on the 'auto' data width which uses parameter propagation to update the widths.
And my specific issue will also occur in 2018.3.
I have the same problem。I hope s_axis_tdata[31:0], m_axis_tdata[23:0].
Can someone give a concise answer of what the purpose of this piece of logic is?
The guide says
The AXI4-Stream Broadcaster provides a solution for replicating a single inbound AXI4-Stream interface into multiple outbound AXI4-Stream interfaces. Support for up to 16 outbound AXI4-Stream interfaces is provided. Each outbound interface also supports an optional remapping feature that allows you to select which TDATA (or TUSER) bits from the inbound interface are present on the TDATA (or TUSER) port of each outbound interface. A block diagram of the broadcaster is shown in Figure 2-1.
Why is it that when I have a single slave interface and two master interfaces, I am getting all signals on each master interface as double the width of the single slave when the master interfaces are configured to be the same width as the slave?
I just want a piece of combinatorial logic to duplicate the input stream N times. This thing is so confusing, I will probably just write and RTL module that does it.
Encountered this problem in Vivado 18.1. Has anyone reached any solution?
I am having the same problem in Vivado 2019.1, is there a fix for this yet?
