problems when using xapp1026
 my device is xupv5lx110t, but the example in the xapp1026.zip based on xc5vlx50t .  I bulid a new project accrodding to the example.  I successfully generate bitstream and generate libraries and Bsps . However , when I want to build a software applications,it have such errors:
/cygdrive/e/Xilinx/10.1/EDK/gnu/microblaze/nt/bin/../lib/gcc/microblaze-xilinx-elf/4.1.1/../../../../microblaze-xilinx-elf/lib/m/crtinit.o: In function `_crtinit':
: undefined reference to `main'
collect2: ld returned 1 exit status
make: *** [TestApp_Peripheral/executable.elf] Error 1
collect2:ld returned 1 exit status
I think the applications have no problem ,  please help me    -_-
are you building the testapp_peripheral applicaiton with xilkernel OS selected?
You need to set compiler options:
In XPS project GUI, right click on software application project (in Applications window),
click on "Set Compiler Options",
go to tab "Path and Options",
provide the following switches in the space provided under "Libraries to link against (-l)" :
-llwip4 -lxilkernel
cheers!!
