processing data samples using microblaze
Actually I am workingon EDK and i am totally new to it.
I have to process the data samples stored in SDRAM in C.
I will be using microblabe in virtex 5 to process these samples.But I dont know how to call these samples stored in SDRAM  in C.
whether i have to use bus or some other functions are there.
Kindly tell the solution for this.
sonicwave
If the SDRAM is correctly connected to the MicroBlaze, it will be mapped to your memory space. That is, one way to use it is to simply assign the base address of the SDRAM to a pointer, and then access the data as an array (if you're doing it this way, then make sure that the SDRAM isn't used for anything else, such as heap/stack/etc).
